Mals Way Fw190A8 R2 (R8?) Sturmbock. Part: 2. Going For A Diorama...
Sida 2 av 12 • 1, 2, 3, ... 10, 11, 12
Sv: Mals Way Fw190A8 R2 (R8?) Sturmbock. Part: 2. Going For A Diorama...
Snyggt som sagt!
Tackar grabbar.....
Det går framåt lol.....
Mera chippning imorrn...nu god mat o vin.....
Blir ju asgrymt, det här.
Möjligen att lite grön överspray kunde förjagas från huven.
Matt_Public- Master of DNF
Detta lovar ju stordåd!
cas- Vicesheriff
Lite material införskaffat, bra o ha.
Gips, spackel, spatel, pensel, trälim.
Samt helomvändning när det gäller fordonet.....
Blir denna, helrätt då jag såg den, Thats The One....
Kul med en något annorlunda kärra!
Inge fel på kubeln, men fasiken den jag hitta e helrätt
so har på ett sätt övat samt kubeln kommer till använding säkert senare
Lite gjort idag.....
Postat på LSP så orkade inte skriva på svenska haha...
Thanks Peter.....
We will se how it goes, and no matter what it will be fun and ill learn something along the way
Allright here is the base, cheap, bouhgt it from Ikea, this one is estetical clean looking frame that i like, also it fits perfect in my glasscabinett...
Masking of that frame..we dont want to dammage it....
Then a wash first...then that oldscool caepenters white glue, oh yes, we need something that will make that carpenters sandputty to stick niceley, yse it do stick real good, then let it dry to get that fine prepped surface....
done now dry.....
mean while im doing them planks, making them out of balsawood, eyeballed some photos to get the right dimension, then cut em, lots of them too is going to be needed.
Lined up that center with filt pen, the center of them planks, now on with that wall sandputty......
And now its still wet, them balsa planks is going to be pressed, so no need to glue, it will stick good....allright done, now a wet painters brush, wet with water to adjust that putty beetwen em planks...
Brushed.....Dont worry about them small cracks, it will be another phase on this cause we are going for that plaster later...
Now dry, and took a photo how its going to look like.....This will doo just fine for me.....My first Dio....
/Mal
Thanks Peter.....
done now dry.....
/Mal
Det här blir snyggt!
Gillar verkligen bilen du fått tag i, så ful att den är söt, precis som en flodhästunge!
Stefan E- Linkebodamannen
@Stefan E skrev:Det här blir snyggt!![]()
Tack Stefan.....man prövar sig fram, har Ernst som hjälper mig mkt med denna m tips o feedback, så har ett vakande öga
Ja, när jag såg den bilen dessutom på rea 188Kr bara, den ska jag ha, den är helrätt för detta jobb, inge fel på kubeln men denna är det det ska vara......
Snyggt jobbat med dioplattan och plankorna!
Anlägga altan till sommaren? Passande värre!
Också: myskomobilen är ju ett fynd!
Grymt kul att se folk som gör dio och hur det går till väga! Har ingen som helst erfarenhet av det men är lite nyfiken. Tavelram var en bra idé! Eller ja, alltihop har varit en aha upplevelse så fortsätt posta!
Tackar Håkan....Ska bli kul o vädra in dem....Har ideer hur göra efter tips från Ernst och Peter...
Japp, en halverad oljeteumma m galler till diot o en back öl till manskapet vore nåt efter amläggandet
@frznlogic skrev:Grymt kul att se folk som gör dio och hur det går till väga! Har ingen som helst erfarenhet av det men är lite nyfiken. Tavelram var en bra idé! Eller ja, alltihop har varit en aha upplevelse så fortsätt posta!
Tack...
detta är mitt första försök.....
har hjälp av Ernst o Peter, samt kollat otal trådar o turorials för tips, sist men inte minst tittat mkt foton med samt samlat på mig lite för detta, ska bli kul o lärorikt
Snygg början på ett Dio Mal! Med lite oljefärg på balsa blir dom riktigt snygga!
Såg denna "skönhet" hade kommit ut. Borde ju gå att montera denna under vingen istället för droptankar.
En sån bordläggning!
Strålande!
Strålande!
cas- Vicesheriff
@Exelon skrev:Snygg början på ett Dio Mal! Med lite oljefärg på balsa blir dom riktigt snygga!
Tackar.
Jag kikade faktiskt på den, apcool den med....men det blir senare....
Tackar.....@cas skrev:En sån bordläggning!
Strålande!
Kollade till den i morse, allt e torrt o fint m krackeleringar i spacklet....
men det visste jag innan, så ska köra lite gips, o snygga till den ytan lite, så fortsättning följer...
Trevlig platta och gips är aldrig fel
Det där har du gjort bra Mal! Snyggt!
» Mals Way Fw190A8 R2 (R8?) Sturmbock. Part: I. The End, It Is Done......
» Mals Way...FW190A8 R2 (R8) Part: I. Stürmbock.
» Mals Adventure FW190A8 continues.....
» Barracudacals P-47 Thunderbolt Part 1, 1/48
» Chipping tutorial Mals Way...Kontrollerat kaos....
IPMS Göteborg :: Modellsnack :: In The Works :: Diorama
Sida 2 av 12
