The 'Junkster' Pod Racer
Sv: The 'Junkster' Pod Racer
Inlägg av tiking i tis jun 28 2016, 17:10
21. I added an extra detail to the Electro attachments on the engines to add more interest to the fuselage. There will be a tiny cable, along with the bigger one, that connects this attachment point with the other smaller one on the pod. For me, the more detail, the better.
tiking
Inlägg av tiking i tis jun 28 2016, 17:42
22. So I started working on the fuselage intakes. Nothing too complicated or advanced, but I thought a slick design would work well for this old beast, even though it is an out-dated design and/or engine. I saved about anything that looks it might work for me in any future builds. I am an astmatic, so I have lots of these cannister lying around. I knew one day they will come in handy. I Still contemplating the design aspect of this section of the build. Will have to do more testing on the over all look later. But so far, this is wht I have.
tiking
Inlägg av tiking i tis jun 28 2016, 17:43
23. Painting the external intakes on the fuselage.
tiking
Inlägg av tiking i tis jun 28 2016, 17:45
24. Added the Electro Attachments to the pod.It's starting to take shape.
tiking
Inlägg av Azgaron i tis jun 28 2016, 18:11
Inte klokt vad snyggt det blir! Smile
Inlägg av tiking i tis jun 28 2016, 18:59
Hihi! Stor tack Håkan. Det närmare sig. 😆
tiking
Inlägg av tiking i tis jun 28 2016, 22:31
25. The overall look, so far on this pod. I think it is starting to look descent enough. Still contemplating the components surrounding the seating compartment. We'll see if I will use both or one or just leave it off entirely.
tiking
Inlägg av tiking i tis jun 28 2016, 22:32
26. The painting is done on the area surrounding the intakes. Will be doing some dry-brushing later on them.
tiking
Inlägg av tiking i tis jun 28 2016, 22:33
27. I think the overall look on this old beast is starting to look pleasing to the eyes.
tiking
Inlägg av Matt_Public i ons jun 29 2016, 12:17
Heliga dykare! Very Happy
Den roströda färgen ser precis lagom snabb ut.
Inlägg av tiking i ons jun 29 2016, 13:14
@Matt_Public skrev:Heliga dykare! Very Happy
Hihi! Tack.
tiking
Inlägg av frznlogic i ons jun 29 2016, 21:03
Så fruktansvärt roligt bygge! Du har fantastisk fantasi och förmåga att göra verklighet av den ☺️
Inlägg av TommyKillander i ons jun 29 2016, 21:38
Vilket fantastiskt bygge! Smile
Inlägg av tiking i tor jun 30 2016, 00:34
@frznlogic skrev:Så fruktansvärt roligt bygge! Du har fantastisk fantasi och förmåga att göra verklighet av den ☺️
Tack för det. Gillar testa nya grejer.
tiking
@TommyKillander skrev:Vilket fantastiskt bygge! Smile
Tack Tommy.
tiking
Inlägg av Stråhatt i tor jun 30 2016, 12:38
Strålande vackert, perfekta färger, älskar skrotkänslan!
Inlägg av tiking i tor jun 30 2016, 14:56
@Stråhatt skrev:Strålande vackert, perfekta färger, älskar skrotkänslan!
Tack för det.
tiking
Inlägg av tiking i tor jun 30 2016, 14:57
28. The little details added.
tiking
Inlägg av tiking i tor jun 30 2016, 14:58
29. The Electro cable that will attach to both the pod and the engine. I used a soldering lead thread is what I used to make the big cable. A thinner steel wire is used to wrap around the bigger cable. THese
will be painted black then dried brush with silver.
tiking
30. The cable attachments. I had the choice of two. The first one and the second version. I choose the second alternative just beacuse of the way it looked.
Alternative 1.
Alternative 2.
Alternative two mounted together and base painted. Will dry brush it before mounting it to the Electro attachments.
The cable will not be glued as I want make any changes if I am not 100% satisfied with the look after mounting it. So there are mount holes at each end that will make it possible to just shove the cable in
the and out it the need arises. This is one of the main reasons I chose to use lead soldering thread as the cable. It makes it possible to pose the cable exactly the way I want it without any movement.
tiking
31. I decided use another wire that I found in a dumspters. I simply cut both ends to reveal the copper wire inside. Then I measured the distance between the two Electro attachments and made the cut. I also
wrapped a much smaller wire around the the thicker one. I just thought it would add to the overall look.Then I primed the wires with black charcoal paint and then dried brushed them with silver.
tiking
Inlägg av tiking i tor jun 30 2016, 15:06
32. Och nu den slut resultat. Lite att puts upp här och där men i princip är det klart. Tror att slut resultat blev ok. Inte den bästa men det duger:
tiking
Inlägg av Azgaron i tor jun 30 2016, 23:29
Grymt coolt bygge! Smile
Inlägg av tiking i tor jun 30 2016, 23:36
Tack Håkan.
tiking
Inlägg av Stefan E i fre jul 01 2016, 16:27
Fantastiskt läcker och helt underbar!  drunken
Men.... borde det inte sitta en ryttare i podden?
